Cannot flash .wic image using UUU tool
2,868件の閲覧回数
karthicknarayanan
I am trying to flash a .wic image to imx8mp using UUU tool in linux. The USB is detected correctly and I am already using sudo but still it shows the following error.
3:1 1/ 0 [Failure open usb device,Try sudo uuu ]
I am using following to command to flash the image
sudo uuu -b emmc_all imx-boot-imx8mp-lpddr4-evk-sd.bin-flash_evk imx-image-core-imx8mp-lpddr4-evk.wic.zst*
5 返答(返信)
2,831件の閲覧回数
jimmychan
Have you try like this?
uuu -b emmc_all imx-image-core-imx8mp-lpddr4-evk.wic.zst
2,817件の閲覧回数
karthicknarayanan
Yes I have tried this command , it was not working.
2,807件の閲覧回数
jimmychan
Are you using i.MX8MP EVK?
Which version of ubuntu are you using? Please try to update the libusb.
Have you try to program the demo image using uuu.auto?
2,848件の閲覧回数
jimmychan
You could try newer release of uuu
https://github.com/nxp-imx/mfgtools/releases
Or you could try to use the Windows version (uuu.exe)
2,845件の閲覧回数
karthicknarayanan
Thanks for the reply jimmy chan
I am getting same issue again after trying it with newer version UUU and we need to work it with linux
