Cannot boot imx28evk from SD card
1,848 次查看
swainsun
Hi Bros,
I'm a new guy of embeded dev, using i.mx28evk.
I fellow the step by step doc to config the vm, installed ubuntu 10.04 on my vmware. I downloaded the L2.6.35_10.12.01_SDK_source_bundle, and fellow the instructions of the guide doc. The ltib installed quickly, and during the ./ltib process, the required pkgs were installed and solved the mtd-utils pkg build failed issue. And normally, i used the mk_mx28_sd script write the boot stream, fs, kernel to the SD card. But error existed when i power the board on.
Here goes the error,
And attched is my config file, anyone can help me?
Thanks, thanks.
Original Attachment has been moved to: imx28.config.zip
标记 (1)
1,682 次查看
Yuri
As I remember the mk_mx28_sd script does not work correctly under Ubuntu 12.04.
Please try using the MFG to deploy images to SD.
1,682 次查看
swainsun
Thanks for your quick replay, but i dont use Ubuntu 12.04, using Ubuntu 10.04.
