Can the timing parameter of IPU CSI be adjusted by programming?
1,516 次查看
flagbee
I'm working on making ov5642 8bit parallel camera using i.MX 6Quad.
There are no issues right now but I just wonder how can I adjust the timing parameter of data lines.
I've already read the datasheet of i.MX 6Quad(Table 59. Sensor Interface Timing Characteristics), but I could not get any information.
How can I compensate the timing error by programming?
1,485 次查看
Hi Jeonghun
there are no ways to compensate timing errors by programming, so it is necessary
in hardware to comply with  timings.
