Can't find a setting in memuconfig in L4.1.15
3,165件の閲覧回数
ko-hey
Senior Contributor II
Hi all
I'm testing a following thread in SABRE-SD with L4.1.15.
I understand that I have to change a configuration by menuconfig but I can't find a setting in menuconfig window.
https://community.nxp.com/docs/DOC-95014
Could someone tell me the settings if you know ?
Ko-hey
2,921件の閲覧回数
joanxie
you can set .config file directly, the path is <the source code you built>/git, then you use “gedit .config”, you can find all of settings, then you can change what you want to
5 返答(返信)
2,921件の閲覧回数
joanxie
pls refer to the yocto trainig:
https://community.nxp.com/docs/DOC-95045
2,924件の閲覧回数
akifumiokano
joanxie, please follow-up kko-hey's question
2,924件の閲覧回数
ko-hey
Hi Joan Xie
Thank you for reply.
I know that I can open a configuration window by using following command.
$ bitbake -c menuconfig linux-imx
My question is which do I select in following choices.
Could you tell me that ?
Ko-hey
2,922件の閲覧回数
joanxie
2,924件の閲覧回数
ko-hey
Hi joanxie
Could you follow and answer this thread ?
Ko-hey
