Can't build Android Things images
1,651 次查看
stefanosanna
Following the instructions in the PICO-i MX6UL-QSG.pdf document, I'm not able to self-build the Android Things images for the PICO board. More precisely, the command "lunch iot_imx6ul_pico-eng" fails because the "iot_imx6ul_pico-eng" configuration does not exist. Probably it needs a different bootloader, I was unable to find it. Where may I find update information on this topic?
Thank you.
Stefano.
标签 (2)
标记 (2)
1,194 次查看
robertthompsons
Do to a last minute change by Google the source for Android Things will not be pushed to the AOSP until code is production ready. Based on this currently only the binary image is available from System Image Downloads | Android Things
The updated docs can be found at: Android Things with i.MX 6UL|NXP
1,195 次查看
robertthompsons
