Can someone point me to the cpu temperature sensor calibration procedure on the iMX6 device?
2,823 次查看
philipchapman
I need the procedure to calibrate the iMX6 internal temperature sensor.
can someone point me to the process
5 回复数
2,298 次查看
kshitij_shah
Hi Igor,
If you know someone who has more information, please provide the contact details.
Also "5.4.1.4 Local temperature sensor placement" has two tables with list of sensors, which one is correct?
2,298 次查看
Hi Kshitij
please create new thread for questions related to i.MX8M processor, as
this thread was for i.MX6.
Regarding i.MX8M, unfortunately I am not aware who has more information,
in general you can get more info in local nxp marketing office.
2,298 次查看
kshitij_shah
Hi Igor,
Can you please point to documentation for process to do sensor calibration on iMX8M ?
2,298 次查看
Hi Kshitij
one can look on sect.5.4.2.18 TMU Temperature Range n Control register (TMU_TTRnCR)
i.MX8MDQ Reference Manual
https://www.nxp.com/docs/en/reference-manual/IMX8MDQLQRM.pdf
I am not aware of additional documentation on that subject.
2,298 次查看
Hi Philip
please check AN5215 i.MX6 Temperature Sensor Module
http://www.nxp.com/docs/en/application-note/AN5215.pdf
