Can anyone explain how and where display is configured in windows 10 IoT for imx8mq ?
1,597 次查看
abhishek_hegde1
In imx-iotcore\driver\video\imxdod directory, I found display driver which has code related to HDMI for imx8mq and MIPI DSI, LCDIF for imx8mm. But the driver seems incomplete as there is no code for DCSS for imx8mq, yet I get the display in my HDMI monitor. How does it work ?
I need more information as I intend to add support for MIPI DSI LED panel.
1,206 次查看
AldoG
If the information still have some value, I believe the i.MX 8MQ image of windows 10 iot does not use DCSS, rather it uses LCDIF, those files are in the directories you had already found.
Hope this helps,
Aldo.
