Can MEMS oscillators replace quartz crystal oscillators?
2,672件の閲覧回数
torus1000
2,301件の閲覧回数
Hi torus1000
in general yes they can be replaced, based on frequency stability
described in i.MX6 System Development User’s Guide
https://www.nxp.com/docs/en/user-guide/IMX6DQ6SDLHDG.pdf
Probably one will have to place level shifter, please check datasheet of
specific mems chip and Development User’s Guide for necessary signal levels.
3 返答(返信)
2,302件の閲覧回数
Hi torus1000
2,301件の閲覧回数
torus1000
Dear Igor igorpadykov
> please check ... and Development User’s Guide for necessary signal levels.
Actually our client use MCIMX7D-SDB.
So I checked IMX7DSHDG.pdf then found follwing description.
https://community.nxp.com/message/820468?commentID=820468#comment-820468
https://www.nxp.com/docs/en/user-guide/IMX7DSHDG.pdf
  For RTC_XTALI VIL and VIH voltage levels, see the
  latest i.MX 7 series datasheet available at nxp.com.
But I couldn't find neither VIL nor VIH in the latest datasheet.
https://www.nxp.com/docs/en/data-sheet/IMX7DCEC.pdf
https://community.nxp.com/message/360353
  Unfortunately we do not have such detail information of the XTAL spec.
(Q1) Did your answer "necessary signal levels" mean VIL and VIH?
(Q2) If yes, where can I get VIL and VIH spec for RTC_XTALI and XTALI pins?
Thanks.
2,301件の閲覧回数
Hi torus1000
yes
