Camera streaming using imx8mm
hsiddiquee
I'm using imx8mm evk board and NXP camera. We need to stream MINISASTOCSI camera video attached to imx8 on a 720x1280 resolution display we have. I have no experience with the board. Can anyone please, direct me to the right documentation or if can explain me how I can achieve it.
I would also like to mention that we are using UI that run on this 720x1280 display. We are thinking to blend the camera image with the video driver that runs the UI.
Please, let me know where I can see the required documents.
Thank you
Tags (2)
Hi hsiddiquee
one can look at documentation provided on
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8-GStreamer-User-Guide/ta-p/1098942
