Camera bring-up with imx95
Rathore-pioneer
Hi All,
I am using the imx95 SVS setup
imx95[SOC] + MX95MBDES01[MAX96724] ===> {mx95mbcam[0x03C10+MAX96717F]+mx95mbcam[0x03C10+MAX96717F]+mx95mbcam[0x03C10+MAX96717F]+custom_cam[0x03H10+MAX96717]}
So basically, the entire setup is the same as SVS, but just changed the cam3 with a custom camera module [0x03H10+MAX96717].
I am making driver modifications but am facing an issue with the GMSL link lock.
My custom camera module runs with this configuration:
I2C Address: 0x84;Xtal Configuration
Coax-Pixel Mode,6Gbps
I can only see cam0-3:
root@imx95-19x19-lpddr5-evk:~# i2cdetect -l
i2c-1 i2c 44350000.i2c I2C adapter
i2c-2 i2c 42530000.i2c I2C adapter
i2c-3 i2c 42540000.i2c I2C adapter
i2c-4 i2c 426b0000.i2c I2C adapter
i2c-5 i2c 426c0000.i2c I2C adapter
i2c-6 i2c 426d0000.i2c I2C adapter
i2c-8 i2c i2c-2-mux (chan_id 0) I2C adapter
i2c-9 i2c i2c-2-mux (chan_id 1) I2C adapter
i2c-10 i2c i2c-2-mux (chan_id 2) I2C adapter
Please suggest a solution.
yipingwang
For i.MX95 ISP, the tuning .bin (DTP database) files are not generated automatically from the BSP. According to the internal i.MX95 Camera Porting Guide and ISP training material:
  • Sensor-specific tuning files are generated using the MMS Tuning Tool.
  • The output is a tuning database file named like:
database_<sensor>_<mode>_<resolution>_<bitdepth>.bin
Example:
database_os08a20_SDR_3840-2160_12bpp.bin
These files are installed under:
/usr/share/libcamera/ipa/nxp/neo/uguzzi/
and are referenced by the IPA configuration
db16122
clear the camera without dust in the front; modify the background light and make the image more clean; modify the brightness and contrastness and check the result; modify the cable connect and make the joint robust
btw, the MAX96717F and MAX96717 may have some parameter difference with serdes configuration
Rathore-pioneer
I got this fixed by running a correct SerDes config.
Now, the camera is up, but getting too white video data.
How can I do Image tunning?
Attached a video for reference.
Rathore-pioneer
I got the image as output. How do I do image tuning:
Attached the image and data which I have used.
yipingwang
First check: Is ISP actually being used?
Run:
libcamera-hello --list-cameras
or
media-ctl -p
and verify the stream is going through:
Sensor
-> ISI
-> ISP
-> libcamera
If you're bypassing the ISP and displaying RAW data directly, image quality will look very poor. The i.MX95 camera subsystem is designed to use the ISP for RAW Bayer sensors.
Common cause #1: Wrong Bayer pattern
You replaced the SVS sensor:
OX03C10
with:
OX03H10
One of the first things to verify is:
BGGR
RGGB
GRBG
GBRG
If the Bayer order configured in the driver differs from the sensor output format, the image often appears:
  • extremely bright
  • wrong colors
  • pink/magenta tint
  • green tint
Check the sensor mode table and DT endpoint configuration.
Common cause #2: Exposure too high
Try forcing exposure manually.
For example:
v4l2-ctl -d /dev/v4l-subdevX --all
Check:
exposure
analog gain
digital gain
If exposure is fixed at a large value, the image will become completely white.
Common cause #3: AE/AWB not working
The i.MX95 ISP uses calibration/tuning information and IPA algorithms for:
  • AE (Auto Exposure)
  • AWB (Auto White Balance)
  • Color correction
  • Denoise
  • Gamma
The camera porting guide states that a sensor-specific configuration and calibration database must be created for a new sensor.
If you simply copied the OX03C10 driver and changed the sensor ID, the ISP may still be loading OX03C10 tuning parameters, which are incorrect for OX03H10.
Common cause #4: Wrong DTP / calibration database
For i.MX95, tuning parameters are stored in sensor-specific database files:
The porting guide states that a dedicated calibration file must be created for a new sensor and installed through the IPA configuration.
Without proper calibration:
  • exposure can be unstable
  • white balance can be wrong
  • colors can be inaccurate
  • image may appear washed out
Rathore-pioneer
How to generate tuning bin files?
yipingwang
Example:
Rathore-pioneer
Yes, that's correct
db16122
so the orginal setup has 4 camera modules with MAX96724,right now you change one of the module cam3 with custom camera module MAX96717 and you can not find it. The module is chan_id 3,right?
%3CLINGO-SUB%20id%3D%22lingo-sub-2388796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECamera%20bring-up%20with%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20All%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20am%20using%20the%20imx95%20SVS%20setup%3C%2FP%3E%3CP%3Eimx95%5BSOC%5D%20%2B%20MX95MBDES01%5BMAX96724%5D%20%3D%3D%3D%26gt%3B%20%7Bmx95mbcam%5B0x03C10%2BMAX96717F%5D%2Bmx95mbcam%5B0x03C10%2BMAX96717F%5D%2Bmx95mbcam%5B0x03C10%2BMAX96717F%5D%2Bcustom_cam%5B0x03H10%2BMAX96717%5D%7D%3C%2FP%3E%3CP%3ESo%20basically%2C%20the%20entire%20setup%20is%20the%20same%20as%20SVS%2C%20but%20just%20changed%20the%20cam3%20with%20a%20custom%20camera%20module%26nbsp%3B%5B0x03H10%2BMAX96717%5D.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20am%20making%20driver%20modifications%20but%20am%20facing%20an%20issue%20with%20the%20GMSL%20link%20lock.%3CBR%20%2F%3EMy%20custom%20camera%20module%20runs%20with%20this%20configuration%3A%3CBR%20%2F%3EI2C%20Address%3A%200x84%3BXtal%20Configuration%3CBR%20%2F%3ECoax-Pixel%20Mode%2C6Gbps%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20can%20only%20see%20cam0-3%3A%3CBR%20%2F%3Eroot%40imx95-19x19-lpddr5-evk%3A~%23%20i2cdetect%20-l%3CBR%20%2F%3Ei2c-1%20i2c%2044350000.i2c%20I2C%20adapter%3CBR%20%2F%3Ei2c-2%20i2c%2042530000.i2c%20I2C%20adapter%3CBR%20%2F%3Ei2c-3%20i2c%2042540000.i2c%20I2C%20adapter%3CBR%20%2F%3Ei2c-4%20i2c%20426b0000.i2c%20I2C%20adapter%3CBR%20%2F%3Ei2c-5%20i2c%20426c0000.i2c%20I2C%20adapter%3CBR%20%2F%3Ei2c-6%20i2c%20426d0000.i2c%20I2C%20adapter%3CBR%20%2F%3Ei2c-8%20i2c%20i2c-2-mux%20(chan_id%200)%20I2C%20adapter%3CBR%20%2F%3Ei2c-9%20i2c%20i2c-2-mux%20(chan_id%201)%20I2C%20adapter%3CBR%20%2F%3Ei2c-10%20i2c%20i2c-2-mux%20(chan_id%202)%20I2C%20adapter%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EPlease%20suggest%20a%20solution.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20bring-up%20with%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eso%20the%20orginal%20setup%20has%204%20camera%20modules%20with%26nbsp%3B%3CSPAN%3EMAX96724%EF%BC%8Cright%20now%20you%20change%20one%20of%20the%20module%20cam3%20with%26nbsp%3Bcustom%20camera%20module%20MAX96717%20and%20you%20can%20not%20find%20it.%20The%20module%20is%26nbsp%3Bchan_id%203%EF%BC%8Cright%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20bring-up%20with%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20that's%20correct%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20bring-up%20with%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20got%20this%20fixed%20by%20running%20a%20correct%20SerDes%20config.%3CBR%20%2F%3ENow%2C%20the%20camera%20is%20up%2C%20but%20getting%20too%20white%20video%20data.%3CBR%20%2F%3EHow%20can%20I%20do%20Image%20tunning%3F%3CBR%20%2F%3EAttached%20a%20video%20for%20reference.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20bring-up%20with%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20got%20the%20image%20as%20output.%20How%20do%20I%20do%20image%20tuning%3A%3CBR%20%2F%3EAttached%20the%20image%20and%20data%20which%20I%20have%20used.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20bring-up%20with%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EFirst%20check%3A%20Is%20ISP%20actually%20being%20used%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ERun%3A%3C%2FP%3E%0A%3CP%3Elibcamera-hello%20--list-cameras%3C%2FP%3E%0A%3CP%3Eor%3C%2FP%3E%0A%3CP%3Emedia-ctl%20-p%3C%2FP%3E%0A%3CP%3Eand%20verify%20the%20stream%20is%20going%20through%3A%3C%2FP%3E%0A%3CP%3ESensor%3C%2FP%3E%0A%3CP%3E-%26gt%3B%20ISI%3C%2FP%3E%0A%3CP%3E-%26gt%3B%20ISP%3C%2FP%3E%0A%3CP%3E-%26gt%3B%20libcamera%3C%2FP%3E%0A%3CP%3EIf%20you're%20bypassing%20the%20ISP%20and%20displaying%20RAW%20data%20directly%2C%20image%20quality%20will%20look%20very%20poor.%20The%20i.MX95%20camera%20subsystem%20is%20designed%20to%20use%20the%20ISP%20for%20RAW%20Bayer%20sensors.%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ECommon%20cause%20%231%3A%20Wrong%20Bayer%20pattern%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EYou%20replaced%20the%20SVS%20sensor%3A%3C%2FP%3E%0A%3CP%3EOX03C10%3C%2FP%3E%0A%3CP%3Ewith%3A%3C%2FP%3E%0A%3CP%3EOX03H10%3C%2FP%3E%0A%3CP%3EOne%20of%20the%20first%20things%20to%20verify%20is%3A%3C%2FP%3E%0A%3CP%3EBGGR%3C%2FP%3E%0A%3CP%3ERGGB%3C%2FP%3E%0A%3CP%3EGRBG%3C%2FP%3E%0A%3CP%3EGBRG%3C%2FP%3E%0A%3CP%3EIf%20the%20Bayer%20order%20configured%20in%20the%20driver%20differs%20from%20the%20sensor%20output%20format%2C%20the%20image%20often%20appears%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Eextremely%20bright%3C%2FLI%3E%0A%3CLI%3Ewrong%20colors%3C%2FLI%3E%0A%3CLI%3Epink%2Fmagenta%20tint%3C%2FLI%3E%0A%3CLI%3Egreen%20tint%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3ECheck%20the%20sensor%20mode%20table%20and%20DT%20endpoint%20configuration.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3ECommon%20cause%20%232%3A%20Exposure%20too%20high%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ETry%20forcing%20exposure%20manually.%3C%2FP%3E%0A%3CP%3EFor%20example%3A%3C%2FP%3E%0A%3CP%3Ev4l2-ctl%20-d%20%2Fdev%2Fv4l-subdevX%20--all%3C%2FP%3E%0A%3CP%3E%60%60%3C%2FP%3E%0A%3CP%3ECheck%3A%3C%2FP%3E%0A%3CP%3Eexposure%3C%2FP%3E%0A%3CP%3Eanalog%20gain%3C%2FP%3E%0A%3CP%3Edigital%20gain%3C%2FP%3E%0A%3CP%3EIf%20exposure%20is%20fixed%20at%20a%20large%20value%2C%20the%20image%20will%20become%20completely%20white.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3ECommon%20cause%20%233%3A%20AE%2FAWB%20not%20working%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EThe%20i.MX95%20ISP%20uses%20calibration%2Ftuning%20information%20and%20IPA%20algorithms%20for%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EAE%20(Auto%20Exposure)%3C%2FLI%3E%0A%3CLI%3EAWB%20(Auto%20White%20Balance)%3C%2FLI%3E%0A%3CLI%3EColor%20correction%3C%2FLI%3E%0A%3CLI%3EDenoise%3C%2FLI%3E%0A%3CLI%3EGamma%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EThe%20camera%20porting%20guide%20states%20that%20a%20sensor-specific%20configuration%20and%20calibration%20database%20must%20be%20created%20for%20a%20new%20sensor.%3C%2FP%3E%0A%3CP%3EIf%20you%20simply%20copied%20the%20OX03C10%20driver%20and%20changed%20the%20sensor%20ID%2C%20the%20ISP%20may%20still%20be%20loading%20OX03C10%20tuning%20parameters%2C%20which%20are%20incorrect%20for%20OX03H10.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3ECommon%20cause%20%234%3A%20Wrong%20DTP%20%2F%20calibration%20database%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EFor%20i.MX95%2C%20tuning%20parameters%20are%20stored%20in%20sensor-specific%20database%20files%3A%3C%2FP%3E%0A%3CP%3Edatabase_%3CSENSOR%3E_%3CMODE%3E_%3CRESOLUTION%3E_%3CBITDEPTH%3E.bin%3C%2FBITDEPTH%3E%3C%2FRESOLUTION%3E%3C%2FMODE%3E%3C%2FSENSOR%3E%3C%2FP%3E%0A%3CP%3EThe%20porting%20guide%20states%20that%20a%20dedicated%20calibration%20file%20must%20be%20created%20for%20a%20new%20sensor%20and%20installed%20through%20the%20IPA%20configuration.%3C%2FP%3E%0A%3CP%3EWithout%20proper%20calibration%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Eexposure%20can%20be%20unstable%3C%2FLI%3E%0A%3CLI%3Ewhite%20balance%20can%20be%20wrong%3C%2FLI%3E%0A%3CLI%3Ecolors%20can%20be%20inaccurate%3C%2FLI%3E%0A%3CLI%3Eimage%20may%20appear%20washed%20out%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390414%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20bring-up%20with%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390414%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20to%20generate%20tuning%20bin%20files%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20bring-up%20with%20imx95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eclear%20the%20camera%20without%20dust%20in%20the%20front%3B%20modify%20the%20background%20light%20and%20make%20the%20image%20more%20clean%3B%20modify%20the%20brightness%20and%20contrastness%20and%20check%20the%20result%3B%20modify%20the%20cable%20connect%20and%20make%20the%20joint%20robust%3C%2FP%3E%3CP%3Ebtw%2C%20the%26nbsp%3B%3CSPAN%3EMAX96717F%20and%20MAX96717%20may%20have%20some%20parameter%20difference%20with%20serdes%20configuration%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
