CTS failures - android.media.cts.EncodeDecodeTest
2,246 次查看
joshlopez
When running android.media.cts.EncodeDecodeTest, we've noticed the following four failures:
  • testEncodeDecodeVideoFromBufferToBufferQCIF
  • testEncodeDecodeVideoFromBufferToBufferQVGA
  • testVP8EncodeDecodeVideoFromBufferToBufferQCIF
  • testVP8EncodeDecodeVideoFromBufferToBufferQVGA
Each of those tests fails with:
junit.framework.AssertionFailedError: Found 30 bad frames
at junit.framework.Assert.fail(Assert.java:50)
We ran these tests both on our hardware as well as the Sabre board and encountered the same failure as both.  It appears others might have run into this as well (https://community.freescale.com/thread/384478).  Has a solution been found?
标记 (1)
1,705 次查看
SergioSolis
Can you please tell me which board are you using and how did you perform the CTS test so I can replicate it?
