CS42888 Mic not working
3,232 次查看
UM
We have tried 3.5mm jack on i.mx 8 quad max board where the mic and speakers(headphones) are working successfully in android automotive. But for the imx-aud-io card (cs42888) speakers are working but the mic in does not take the input or record voice we have used the given command tinycap test.wav -D 1 -d 0 -c 2 -r 48000 -b 16 to capture voice .......What can be the solution for this issue.
Note :- We are using android automotive 12 version.
Thanks and Regards,
UM
3,165 次查看
JorgeCas
Thank you for the information.
I suggest you take a look on the next thread, maybe could be helpful to your issue.
Best regards.
5 回复数
3,215 次查看
JorgeCas
Hello, I hope you are doing well.
I suggest you take a look on audio route of Android Auto User's guide (8.2.1 Routing audio stream to different sound cards).
Best regards.
3,210 次查看
UM
I have followed all the steps for routing audio stream still my microphone is not working on imx-aud-io board.
Note :- We can hear music from speakers on the audio board but it does not take microphone input.
Could you please suggest other alternative.
Best regards.
3,206 次查看
JorgeCas
Got it, thank you for the information.
Is this happening only on Android OS? What about Linux?
Which connector are you using to connect the microphone? Which microphone are you using?
Best regards.
3,185 次查看
UM
Its happening with both the OS Android as well as Linux.
We are using the RCA connector.
The microphone we are using is the 3.5mm jack collar microphone which we have soldered to the RCA connector...
Best regards.
3,166 次查看
JorgeCas
Best regards.
