Hi all,
i can able to cross compile qt4.8.5 into imx6 arm platform. But i unable to cross compile qt5.5.0 into imx6 arm platform.
Can you please guide me to do this.
Aravinth
There is a recent post on the official Qt forum about that. It's not dedicated to the iMX6 but it should work for any SBC running Linux.
[TUTO] Build Qt to cross compile for arm | Qt Forum
Hi rogeriopimentel
Thanks for your response.
AJ
Hi joanxie
Thanks for your response. Customer requirement is 5.5.0 so i want that only.
Here is a good how to.
http://wiki.wandboard.org/index.php/Building_Qt5_using_yocto_on_Wandboard
I hope it can help you.
the latest qt version is qt 5.6, did you try it?
http://t.hsms02.com/e1t/c/*W3V6YkD4nGs_zW7lcqg787zZMQ0/*W1WlFCH7kHH1zW2MK3Vz3FLlDY0/5/f18dQhb0Smh_8Y...Qt - Qt 5.6
