CHIP_SELECT and CHANNEL_SELECT
已解决
跳至解决方案
2,374 次查看
KeshavaGN
Contributor V
Hi all,
A doubt. Sorry if this seems to be silly..
While developing a device driver (SPI), i came across two terms (in codes from two different resources): CHIP_SELECT and CHANNEL_SELECT.
My question is, in general, there chip select and channel select both are same? or different? If different, please explain about channel select...
Thanks...
With regards,
Keshava G N
1 解答
2,165 次查看
LinWang
在原帖中查看解决方案
2 回复数
2,166 次查看
LinWang
2,165 次查看
KeshavaGN
Contributor V
Thank you LinWang, for clarification...
KeshavaGN
