Hi T. Y.,
Could you please tell me which detail clock you want to output in CCM_CLKO2 from GPIO_SD_B0_05?
I find your code is choose the sai1_clk_root.
Do you already enable the related clock?
Please tell me which detail code you want to output, then I will also help you to test it.
Kerry
