CAAM and kernel crypto tests
11,690 次查看
EricNelson
Senior Contributor II
Hi all,
We're seeing some disconcerting error messages on various versions of Linux and various boards when enabling CAAM and
the kernel self-tests.
Testing on SABRE-SD with 3.10.31-alpha
root@imx6qsabresd:~# dmesg
alg: hash: Test 1 failed for hmac-sha1-caam
00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000010: f1 46 be 00
alg: hash: Test 1 failed for sha1-caam
00000010: 9c d0 d8 9d
alg: hash: Test 1 failed for hmac-sha224-caam
00000010: 47 b4 b1 16 99 12 ba 4f 53 68 4b 22
alg: hash: Test 1 failed for sha224-caam
00000010: 2a ad bc e4 bd a0 b3 f7 e3 6c 9d a7
root@imx6qsabresd:~# cat /proc/cmdline
console=ttymxc0,115200 ip=dhcp root=/dev/mmcblk0p2 rootwait caam
The kernel configuration is essentially the same as the stock v7_defconfig with a few additional debug flags:
~/linux-imx6$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- savedefconfig
scripts/kconfig/conf --savedefconfig=defconfig Kconfig
~/linux-imx6$ diff defconfig arch/arm/configs/imx_v7_defconfig
253a254
> CONFIG_USB_PHY=y
329d329
< CONFIG_DEBUG_LOCK_ALLOC=y
334d333
< # CONFIG_CRYPTO_MANAGER_DISABLE_TESTS is not set
We've seen the same results with kernel 3.0.35_4.1.0 and 3.10.17-1.0.0-ga on Nitrogen6x.
Does anyone have some insight about this?
Thanks in advance,
Eric
标签 (2)
标记 (3)
9,671 次查看
EricNelson
Thanks to Steve Cornelius and others at Freescale, we've been able to show that this issue has to do with cache coherency.
In particular, the CAAM drivers expect all inputs and outputs to be aligned with on a cache line boundary (32 bytes on i.MX6).
Since the testmgr code was originally created to test software implementations, as of kernel 3.10.17, it didn't ensure any particular alignment, which caused the failures, and a simple update to address this prevents the errors:
         crypto testmgr: Align result buffer on cache-line · e3e7ad4 · boundarydevices/linux-imx6 · GitHub
As mentioned in the commit log, this requirement for inputs and outputs also exists in userspace code, so applications will need to take care in allocations.
14 回复数
4,455 次查看
cryptolover
SecretCryptos is your one-stop solution for anonymous crypto transactions. Whether you're looking to use a crypto mixer or trade on a secure exchange, SecretCryptos ensures full privacy and anonymity for all your transactions.
SecretCryptos Crypto Mixer and Exchange
All Mixer Pages (per coin)
SecretCryptos Crypto Mixer | Bitcoin (BTC) Mixer | Ethereum (ETH) Mixer | Tether (USDT) Mixer | USD Coin (USDC) Mixer | BNB (BSC) Mixer | Litecoin (LTC) Mixer | Dogecoin (DOGE) Mixer | XRP (Ripple) Mixer | Solana (SOL) Mixer | TRON (TRX) Mixer | TON (Toncoin) Mixer | Polygon (MATIC) Mixer | Avalanche (AVAX) Mixer | Cardano (ADA) Mixer | Polkadot (DOT) Mixer | Shiba Inu (SHIB) Mixer
Instant Crypto Exchange
Crypto Exchange
62a314_66eab6e98f404d46a2d43c76933e6802~mv2
9,672 次查看
EricNelson
9,671 次查看
jonnettleton
There are actually proper fixes to this problem in Herbert Xu's crypto-2.6 tree.  Specifically LKML: Herbert Xu: Crypto Fixes for 3.13 and LKML: Herbert Xu: Re: Crypto Fixes for 3.13 fix the problems.  They would need to be backported to 3.10.xx
9,671 次查看
EricNelson
Many thanks, Jon
9,671 次查看
EricNelson
Additional notes:
The values shown in the test failures:
  1. alg: hash: Test 1 failed for hmac-sha1-caam
  2. 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  3. 00000010: f1 46 be 00
Appear to be similar to the expected results. This is the first test vector for hmac-sha1 in crypto/testmgr.c:
static struct hash_testvec hmac_sha1_tv_template[] = {
  .key = "\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b",
  .ksize = 20,
  .plaintext = "Hi There",
  .psize = 8,
  .digest = "\xb6\x17\x31\x86\x55\x05\x72\x64"
   "\xe2\x8b\xc0\xb6\xfb\x37\x8c\x8e\xf1"
   "\x46\xbe",
Note that the sequence "f1 46 be" matches the expected value.
Also note that the first 16 bytes of each of the failed tests is showing as zero.
9,671 次查看
EricNelson
Yet more information regarding these tests...
A udelay(20) call at the end of caam_jr_enqueue() allows the tests to succeed, so it appears to be some form of timing bug.
~/linux-imx6$ git diff
diff --git a/drivers/crypto/caam/jr.c b/drivers/crypto/caam/jr.c
index 80ddddb..c8c4a7e 100644
--- a/drivers/crypto/caam/jr.c
+++ b/drivers/crypto/caam/jr.c
@@ -288,6 +288,7 @@ int caam_jr_enqueue(struct device *dev, u32 *desc,
        spin_unlock_bh(&jrp->inplock);
+       udelay(20);
        return 0;
EXPORT_SYMBOL(caam_jr_enqueue);
9,671 次查看
EricNelson
9,671 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
jamesbone can you continue with the follow up on this case?
9,671 次查看
seungwonkim
Is this problem fixed?? or, solution is just delay???
I have the problem too. but, I need to change delay value up to 100usec for successful test.
It is big problem.
9,671 次查看
EricNelson
Not fixed yet.
9,671 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
jamesbone do you have an update of this case?
9,671 次查看
EricNelson
Further update: In a subsequent boot on 3.10.17-1.0.0-ga, I'm seeing only 8 bytes of zeros:
00000000: 00 00 00 00 00 00 00 00 e2 8b c0 b6 fb 37 8c 8e
9,671 次查看
EricNelson
Hi Jaime,
I think you missed that we're testing against 3.0.35_4.1.0, 3.10.17-1.0.0-ga, and 3.10.31_1.0.0-alpha.
Each of them already contains the patches from the other page:
Patch to dma_map_sg_chained:
     http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_3.0.35_4.0.0&id=b30237c790...
3.10.17 sources:
     https://github.com/boundarydevices/linux-imx6/blob/boundary-imx_3.10.17_1.0.0_ga/drivers/crypto/caam...
Patch to driver_algs:
     http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_3.0.35_4.0.0&id=6068d7a77b...
3.10.17 sources:
I also wasn't clear that the problem we're seeing is only with the hash algorithms.
Eric
9,671 次查看
jamesbone
Dear Eric,
On linux 3.0.35 there is a need for some patches in order to get  proper functionality of CAAM
Q&amp;A: Why is CAAM Driver Not Functioning in Linux for iMX6?
Jaime
%3CLINGO-SUB%20id%3D%22lingo-sub-307488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAAM%20%E5%92%8C%E5%86%85%E6%A0%B8%E5%8A%A0%E5%AF%86%E6%B5%8B%E8%AF%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%AF%E7%94%A8%20CAAM%20%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%89%88%E6%9C%AC%E7%9A%84%20Linux%20%E5%92%8C%E5%90%84%E7%A7%8D%E6%9D%BF%E4%B8%8A%E7%9C%8B%E5%88%B0%E4%B8%80%E4%BA%9B%E4%BB%A4%E4%BA%BA%E4%B8%8D%E5%AE%89%E7%9A%84%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E8%87%AA%E6%A3%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%203.10.31-alpha%20%E5%9C%A8%20SABRE-SD%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14013157025046584%20jive_text_macro%20jive_macro_code%22%20jivemacro_uid%3D%22_14013157025046584%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Eroot%40imx6qsabresd%3A~%23%20dmesg%3C%2FP%3E%0A%3CP%3E...%3C%2FP%3E%0A%3CP%3Ealg%3A%20hash%EF%BC%9Ahmac-sha1-caam%20%E6%B5%8B%E8%AF%95%201%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%0A%3CP%3E00000010%3A%20F1%2046%20BE%2000%3C%2FP%3E%0A%3CP%3Ealg%3A%20hash%EF%BC%9A%E5%AF%B9%20sha1-caam%20%E7%9A%84%E6%B5%8B%E8%AF%95%201%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%0A%3CP%3E00000010%3A9C%20D0%20D8%209D%3C%2FP%3E%0A%3CP%3Ealg%3A%20hash%EF%BC%9Ahmac-sha224-caam%20%E6%B5%8B%E8%AF%95%201%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%0A%3CP%3E00000010%3A47%20B4%20B1%2016%2099%2012%20BA%204F%2053%2068%204B%2022%3C%2FP%3E%0A%3CP%3Ealg%3A%20hash%EF%BC%9A%E5%AF%B9%20sha224-caam%20%E7%9A%84%E6%B5%8B%E8%AF%95%201%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%0A%3CP%3E00000010%3A%202A%20AD%20BC%20E4%20BD%20A0%20B3%20F7%20E3%206C%209D%20A7%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Eroot%40imx6qsabresd%3A~%23%20cat%20%2Fproc%2Fcmdline%3C%2FP%3E%0A%3CP%3Econsole%3Dttymxc0%2C115200%20ip%3Ddhcp%20root%3D%2Fdev%2Fmmcblk0p2%20rootwait%20caam%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E4%B8%8E%20v7_defconfig%20%E5%9F%BA%E6%9C%AC%E7%9B%B8%E5%90%8C%EF%BC%8C%E5%8F%AA%E6%98%AF%E5%A2%9E%E5%8A%A0%E4%BA%86%E4%B8%80%E4%BA%9B%E8%B0%83%E8%AF%95%E6%A0%87%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013158290519725%22%20jivemacro_uid%3D%22_14013158290519725%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3E~%2Flinux-imx6%24%20make%20arch%3Darm%20cross_compile%3Darm-linux-GNUEABIHF-savedefconfig%3C%2FP%3E%0A%3CP%3Escripts%2Fkconfig%2Fconf%20--savedefconfig%3Ddefconfig%20Kconfig%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E~%2Flinux-imx6%24%20diff%20diff%20diff%20arch%2Farm%2Fconfigs%2Fimx_v7_defconfig%3C%2FP%3E%0A%3CP%3E253a254%3C%2FP%3E%0A%3CP%3E%26gt%3B%20CONFIG_USB_PHY%3Dy%3C%2FP%3E%0A%3CP%3E329d329%3C%2FP%3E%0A%3CP%3E%26lt%3B%20CONFIG_DEBUG_LOCK_ALLOC%3Dy%3C%2FP%3E%0A%3CP%3E334d333%3C%2FP%3E%0A%3CP%3E%26lt%3B%20%23%20CONFIG_CRYPTO_MANAGER_DISABLE_TESTS%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B8%203.0.35_4.1.0%20%E6%97%B6%E4%B9%9F%E7%9C%8B%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E7%BB%93%E6%9E%9C%E5%92%8C%203.10.17-1.0.0-ga%20on%20Nitrogen6x.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E5%AF%B9%E6%AD%A4%E6%9C%89%E4%BB%80%E4%B9%88%E8%A7%81%E8%A7%A3%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9F%83%E9%87%8C%E5%85%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-307488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESecretCryptos%20%E6%98%AF%E6%82%A8%E5%8C%BF%E5%90%8D%E5%8A%A0%E5%AF%86%E8%B4%A7%E5%B8%81%E4%BA%A4%E6%98%93%E7%9A%84%E4%B8%80%E7%AB%99%E5%BC%8F%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E6%97%A0%E8%AE%BA%E6%82%A8%E6%98%AF%E6%83%B3%E4%BD%BF%E7%94%A8%E5%8A%A0%E5%AF%86%E8%B4%A7%E5%B8%81%E6%B7%B7%E5%90%88%E5%99%A8%E8%BF%98%E6%98%AF%E5%9C%A8%E5%AE%89%E5%85%A8%E4%BA%A4%E6%98%93%E6%89%80%E8%BF%9B%E8%A1%8C%E4%BA%A4%E6%98%93%EF%BC%8CSecretCryptos%20%E9%83%BD%E8%83%BD%E7%A1%AE%E4%BF%9D%E6%82%A8%E6%89%80%E6%9C%89%E4%BA%A4%E6%98%93%E7%9A%84%E5%AE%8C%E5%85%A8%E9%9A%90%E7%A7%81%E6%80%A7%E5%92%8C%E5%8C%BF%E5%90%8D%E6%80%A7%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3ESecretCryptos%20%E5%AF%86%E7%A0%81%E6%B7%B7%E5%90%88%E5%99%A8%E5%92%8C%E4%BA%A4%E6%98%93%E6%89%80%3C%2FU%3E%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%89%80%E6%9C%89%E6%B7%B7%E5%90%88%E5%99%A8%E9%A1%B5%E9%9D%A2%EF%BC%88%E6%AF%8F%E4%B8%AA%E7%A1%AC%E5%B8%81%EF%BC%89%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3ESecretCryptos%20%E5%AF%86%E7%A0%81%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fbitcoin%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E6%AF%94%E7%89%B9%E5%B8%81%20(BTC)%20%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fethereum%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E4%BB%A5%E5%A4%AA%E5%9D%8A%EF%BC%88ETH%EF%BC%89%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Ftether%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E4%BB%A5%E5%A4%AA%E5%9D%8A%EF%BC%88USDT%EF%BC%89%E6%B7%B7%E5%90%88%E5%B8%81%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fusdc%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E7%BE%8E%E5%85%83%E5%B8%81%EF%BC%88USDC%EF%BC%89%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fbnb%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EBNB%20(BSC)%20%E6%B7%B7%E5%90%88%E5%B8%81%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Flitecoin%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E8%8E%B1%E7%89%B9%E5%B8%81%EF%BC%88LTC%EF%BC%89%E6%B7%B7%E5%90%88%E5%B8%81%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fdogecoin%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EDogecoin%20(DOGE)%20%E6%B7%B7%E5%90%88%E5%B8%81%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fxrp%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EXRP%EF%BC%88%E7%91%9E%E6%B3%A2%E5%B8%81%EF%BC%89%E6%B7%B7%E5%90%88%E5%B8%81%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fsolana%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E7%B4%A2%E6%8B%89%E7%BA%B3%EF%BC%88SOL%EF%BC%89%E6%B7%B7%E5%90%88%E5%B8%81%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Ftron%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3ETRON%20(TRX)%20%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Ftoncoin%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3ETON%20(Toncoin)%20%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fpolygon%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E5%A4%9A%E8%BE%B9%E5%BD%A2%EF%BC%88MATIC%EF%BC%89%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Favalanche%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EAvalanche%20(AVAX)%20%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fcardano%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E5%8D%A1%E8%BE%BE%E8%AF%BA%EF%BC%88ADA%EF%BC%89%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fpolkadot%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EPolkadot%20(DOT)%20%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fshiba-inu%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EShiba%20Inu%20(SHIB)%20%E6%B7%B7%E5%90%88%E5%99%A8%3C%2FU%3E%3C%2FA%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1975522908%22%20id%3D%22toc-hId-2001443990%22%3E%E5%8D%B3%E6%97%B6%E5%8A%A0%E5%AF%86%E8%B4%A7%E5%B8%81%E4%BA%A4%E6%98%93%E6%89%80%3C%2FH3%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fcrypto-exchange%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E5%8A%A0%E5%AF%86%E8%B4%A7%E5%B8%81%E4%BA%A4%E6%98%93%E6%89%80%3C%2FU%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20title%3D%22%E5%8A%A0%E5%AF%86%E8%B4%A7%E5%B8%81%E6%B7%B7%E5%90%88%E5%92%8C%E4%BA%A4%E6%8D%A2%22%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2262a314_66eab6e98f404d46a2d43c76933e6802~mv2%22%20style%3D%22width%3A%20761px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2262a314_66eab6e98f404d46a2d43c76933e6802~mv2%22%20style%3D%22width%3A%20761px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357178iC6E0EBA8FB05CCD8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2262a314_66eab6e98f404d46a2d43c76933e6802~mv2%22%20alt%3D%2262a314_66eab6e98f404d46a2d43c76933e6802~mv2%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%E4%B9%94%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E5%9C%A8%20Herbert%20Xu%20%E7%9A%84%20crypto-2.6%20%E4%B8%AD%E5%B7%B2%E7%BB%8F%E5%AF%B9%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E8%BF%9B%E8%A1%8C%E4%BA%86%E9%80%82%E5%BD%93%E7%9A%84%E4%BF%AE%E5%A4%8D%E3%80%82%E6%A0%91%20%E7%89%B9%E5%88%AB%E6%98%AF%3CA%20href%3D%22https%3A%2F%2Flkml.org%2Flkml%2F2013%2F12%2F3%2F240%22%20title%3D%22https%3A%2F%2Flkml.org%2Flkml%2F2013%2F12%2F3%2F240%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELKML%3A%20Herbert%20Xu%EF%BC%9ACrypto%20Fixes%20for%203.13%3C%2FA%3Eand%3CA%20href%3D%22https%3A%2F%2Flkml.org%2Flkml%2F2013%2F12%2F9%2F314%22%20title%3D%22https%3A%2F%2Flkml.org%2Flkml%2F2013%2F12%2F9%2F314%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELKML%3A%20Herbert%20Xu%EF%BC%9ARe%EF%BC%9A3.13%20%E7%9A%84%E5%AF%86%E7%A0%81%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%3C%2FA%3E%E8%A7%A3%E5%86%B3%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%20%E5%AE%83%E4%BB%AC%E9%9C%80%E8%A6%81%E5%90%91%E5%90%8E%E7%A7%BB%E6%A4%8D%E5%88%B0%203.10.xx%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%9A%E4%BA%8F%E4%BA%86%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%9A%84%20Steve%20Cornelius%20%E7%AD%89%E4%BA%BA%EF%BC%8C%E6%88%91%E4%BB%AC%E6%89%8D%E5%BE%97%E4%BB%A5%E8%AF%81%E6%98%8E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8E%E9%AB%98%E9%80%9F%E7%BC%93%E5%AD%98%E4%B8%80%E8%87%B4%E6%80%A7%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%89%B9%E5%88%AB%E6%98%AF%EF%BC%8CCAAM%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%9F%E6%9C%9B%E6%89%80%E6%9C%89%E8%BE%93%E5%85%A5%E5%92%8C%E8%BE%93%E5%87%BA%E5%9C%A8%E7%BC%93%E5%AD%98%E8%A1%8C%E8%BE%B9%E7%95%8C%EF%BC%88i.MX6%E4%B8%8A%E4%B8%BA32%E5%AD%97%E8%8A%82%EF%BC%89%E4%B8%8A%E5%AF%B9%E9%BD%90%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%20testmgr%20%E4%BB%A3%E7%A0%81%E6%9C%80%E5%88%9D%E6%98%AF%E4%B8%BA%E6%B5%8B%E8%AF%95%E8%BD%AF%E4%BB%B6%E5%AE%9E%E7%8E%B0%E8%80%8C%E5%88%9B%E5%BB%BA%E7%9A%84%EF%BC%8C%E4%BB%8E%E5%86%85%E6%A0%B8%203.10.17%20%E5%BC%80%E5%A7%8B%EF%BC%8C%E5%AE%83%E5%B9%B6%E6%B2%A1%E6%9C%89%E7%A1%AE%E4%BF%9D%E4%BB%BB%E4%BD%95%E7%89%B9%E5%AE%9A%E7%9A%84%E5%AF%B9%E9%BD%90%E6%96%B9%E5%BC%8F%EF%BC%8C%E8%BF%99%E5%B0%B1%E5%AF%BC%E8%87%B4%E4%BA%86%E6%95%85%E9%9A%9C%E7%9A%84%E5%8F%91%E7%94%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fcommit%2Fe3e7ad4294491f44826780f691a063677f3c4932%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fcommit%2Fe3e7ad4294491f44826780f691a063677f3c4932%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ecrypto%20testmgr%3A%20%E5%9C%A8%E7%BC%93%E5%AD%98%E8%A1%8C%E4%B8%8A%E5%AF%B9%E9%BD%90%E7%BB%93%E6%9E%9C%E7%BC%93%E5%86%B2%E5%8C%BA%20-%20e3e7ad4%20-%20boundarydevices%2Flinux-imx6%20-%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%A6%82%E6%8F%90%E4%BA%A4%E6%97%A5%E5%BF%97%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E4%BB%A3%E7%A0%81%E4%B8%AD%E4%B9%9F%E5%AD%98%E5%9C%A8%E5%AF%B9%E8%BE%93%E5%85%A5%E5%92%8C%E8%BE%93%E5%87%BA%E7%9A%84%E8%BF%99%E7%A7%8D%E8%A6%81%E6%B1%82%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E5%88%86%E9%85%8D%E6%97%B6%E9%9C%80%E8%A6%81%E5%B0%8F%E5%BF%83%E8%B0%A8%E6%85%8E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22jiveTT-hover-user%20jive-link-profile-small%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2214228%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjamesbone%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%20text-decoration%3A%20underline%3B%22%20target%3D%22_blank%22%3Ejamesbone%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E4%BD%A0%E6%9C%89%E8%BF%99%E4%B8%AA%E6%A1%88%E4%BB%B6%E7%9A%84%E6%9C%80%E6%96%B0%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B0%9A%E6%9C%AA%E4%BF%AE%E5%A4%8D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E6%9C%89%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%E5%BB%B6%E8%BF%9F%E5%80%BC%E6%94%B9%E4%B8%BA%20100usec%20%E6%89%8D%E8%83%BD%E6%88%90%E5%8A%9F%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%A4%A7%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjamesbone%22%20target%3D%22_blank%22%3EJamesbone%3C%2FA%3E%E4%BD%A0%E8%83%BD%E7%BB%A7%E7%BB%AD%E8%B7%9F%E8%BF%9B%E8%BF%99%E4%B8%AA%E6%A1%88%E5%AD%90%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%98%E6%9C%89%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%3CSPAN%20style%3D%22color%3A%20%23990000%3B%20font-family%3A%20Consolas%2C%20'Liberation%20Mono'%2C%20Courier%2C%20monospace%3B%20font-size%3A%2012px%3B%20font-weight%3A%20bold%3B%22%3Ecaam_jr_dequeue%3C%2FSPAN%3E()%20%E7%9A%84%E8%BF%99%E4%B8%A4%E4%B8%AA%E4%BD%8D%E7%BD%AE%E4%B8%AD%E7%9A%84%E4%BB%BB%E4%BD%95%E4%B8%80%E4%B8%AA%E4%BD%8D%E7%BD%AE%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%20udelay(20)%20%E9%83%BD%E4%B8%8D%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%B5%8B%E8%AF%95%E6%88%90%E5%8A%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L66%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L66%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20%20%20%20%20linux-imx6%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%20at%20boundary-imx_3.10.17_1.0.0_ga%20-%20boundarydevices%2Flinux-imx6%20-%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%20%20%20%20%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L128%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L128%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinux-imx6%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%20at%20boundary-imx_3.10.17_1.0.0_ga%20-%20boundarydevices%2Flinux-imx6%20-%20GitHub%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E5%85%B3%E8%BF%99%E4%BA%9B%E6%B5%8B%E8%AF%95%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20caam_jr_enqueue()%20%E7%BB%93%E6%9D%9F%E6%97%B6%E8%B0%83%E7%94%A8%20udelay(20)%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E6%B5%8B%E8%AF%95%E6%88%90%E5%8A%9F%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%E6%9F%90%E7%A7%8D%E5%BD%A2%E5%BC%8F%E7%9A%84%E5%AE%9A%E6%97%B6%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013942705871488%22%20jivemacro_uid%3D%22_14013942705871488%22%3E%0A%3CP%3E~%2Flinux-imx6%24%20git%20diff%3C%2FP%3E%0A%3CP%3Ediff%20--git%20a%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%20b%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%3C%2FP%3E%0A%3CP%3E%E7%B4%A2%E5%BC%95%2080ddddb...c8c4a7e%20100644%3C%2FP%3E%0A%3CP%3E---%20a%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%3C%2FP%3E%0A%3CP%3E%2B%2B%2B%20b%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%3C%2FP%3E%0A%3CP%3E%40%40%20-288%2C6%20%2B288%2C7%20%40%40%20int%20caam_jr_enqueue%20(%E7%BB%93%E6%9E%84%E8%AE%BE%E5%A4%87%20*dev%EF%BC%8Cu32%20*Desc%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%20%20spin_unlock_bh(%26amp%3Bjrp-%26gt%3Binplock)%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%2B%20udelay(20)%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%20%20%E8%BF%94%E5%9B%9E%200%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%20%7D%3C%2FP%3E%0A%3CP%3E%20EXPORT_SYMBOL(caam_jr_enqueue)%EF%BC%9B%3C%2FP%3E%0A%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%9B%B4%E6%96%B0%EF%BC%9A%E5%9C%A8%E9%9A%8F%E5%90%8E%E5%9C%A8%203.10.17-1.0.0-ga%20%E4%B8%8A%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AA%E7%9C%8B%E5%88%B0%E4%BA%86%208%20%E5%AD%97%E8%8A%82%E7%9A%84%E9%9B%B6%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013882538833347%22%20jivemacro_uid%3D%22_14013882538833347%22%3E%0A%3CP%3Ealg%3A%20hash%EF%BC%9Ahmac-sha1-caam%20%E6%B5%8B%E8%AF%95%201%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%20E2%208B%20C0%20B6%20FB%2037%208C%208E%3C%2FP%3E%0A%3CP%3E00000010%3A%20F1%2046%20BE%2000%3C%2FP%3E%0A%3CP%3Ealg%3A%20hash%EF%BC%9A%E5%AF%B9%20sha1-caam%20%E7%9A%84%E6%B5%8B%E8%AF%95%201%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%85%B6%E4%BB%96%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%E6%97%B6%E6%98%BE%E7%A4%BA%E7%9A%84%E6%95%B0%E5%80%BC%EF%BC%9A%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013867085051833%22%20jivemacro_uid%3D%22_14013867085051833%22%3E%3COL%20class%3D%22dp-c%22%20start%3D%221%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20list-style-position%3A%20initial%3B%20list-style-image%3A%20initial%3B%20color%3A%20%235c5c5c%3B%20margin-bottom%3A%201px%20!important%3B%20margin-left%3A%2045px%20!important%3B%22%3E%0A%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20color%3A%20black%3B%20background-color%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3Ealg%3A%20hash%EF%BC%9Ahmac-sha1-caam%20%E6%B5%8B%E8%AF%95%201%20%E5%A4%B1%E8%B4%A5%20%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20color%3A%20black%3B%20background-color%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20color%3A%20black%3B%20background-color%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E00000010%3A%20F1%2046%20BE%2000%20%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%3C%2FPRE%3E%3CP%3E%E4%BC%BC%E4%B9%8E%E4%B8%8E%E9%A2%84%E6%9C%9F%E7%BB%93%E6%9E%9C%E7%9B%B8%E4%BC%BC%E3%80%82%E8%BF%99%E6%98%AF%20crypto%2Ftestmgr.c%20%E4%B8%AD%20hmac-sha1%20%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%B5%8B%E8%AF%95%E5%90%91%E9%87%8F%EF%BC%9A%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013868909418798%22%20jivemacro_uid%3D%22_14013868909418798%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Estatic%20struct%20hash_testvec%20hmac_sha1_tv_template%5B%5D%20%3D%20%7B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%7B%3C%2FP%3E%0A%3CP%3E%20%20key%20%3D%22%5Cx0b%5Cx0b%5Cx0b%5Cx0b%22%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%20%20.ksize%20%3D%2020%E3%80%81%3C%2FP%3E%0A%3CP%3E%20%20.plaintext%20%3D%22%E4%BD%A0%E5%A5%BD%22%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%20%20.psize%20%3D%208%E3%80%81%3C%2FP%3E%0A%3CP%3E%20%20.digest%20%3D%22%5Cxb6%5Cx17%5Cx31%5Cx86%5Cx55%5Cx05%5Cx72%5Cx64%22%3C%2FP%3E%0A%3CP%3E%20%20%22%5Cxe2%5Cx8b%5Cxc0%5Cxb6%5Cxfb%5Cx37%5Cx8c%5Cx8e%5Cxf1%22%3C%2FP%3E%0A%3CP%3E%20%20%22%5Cx46%5Cxbe%22%20%E3%80%81%3C%2FP%3E%0A%3CP%3E...%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%22f1%2046%20be%22%20%E5%BA%8F%E5%88%97%E4%B8%8E%E9%A2%84%E6%9C%9F%E5%80%BC%E7%9B%B8%E5%90%BB%E5%90%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%AF%8F%E9%A1%B9%E5%A4%B1%E8%B4%A5%E6%B5%8B%E8%AF%95%E7%9A%84%E5%89%8D%2016%20%E5%AD%97%E8%8A%82%E6%98%BE%E7%A4%BA%E4%B8%BA%E9%9B%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%B5%B7%E6%A2%85%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BD%A0%E6%B2%A1%E6%B3%A8%E6%84%8F%E5%88%B0%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%203.0.35_4.1.0%E3%80%813.10.17-1.0.0-ga%20%E5%92%8C%203.10.31_1.0.0-alpha%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%AF%8F%E4%B8%AA%E9%A1%B5%E9%9D%A2%E9%83%BD%E5%B7%B2%E5%8C%85%E5%90%AB%E5%85%B6%E4%BB%96%E9%A1%B5%E9%9D%A2%E7%9A%84%E8%A1%A5%E4%B8%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edma_map_sg_chained%20%E8%A1%A5%E4%B8%81%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%3CA%20class%3D%22loading%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3Db30237c79003223c6e8035d5be183cd4f0b469f9%22%20title%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3Db30237c79003223c6e8035d5be183cd4f0b469f9%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3Db30237c79003223c6e8035d5be183cd4f0b469f9%3C%2FA%3E%3C%2FP%3E%3CP%3E3.10.17%20%E4%BF%A1%E6%81%AF%E6%9D%A5%E6%BA%90%3C%2FP%3E%3CP%3E%20%20%20%20%20%3CA%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fsg_sw_sec4.h%23L96%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fsg_sw_sec4.h%23L96%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fsg_sw_sec4.h%23L96%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%BB%99%20driver_algs%20%E6%89%93%E8%A1%A5%E4%B8%81%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%3CA%20class%3D%22loading%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3D6068d7a77b2101c172fc2f003f90b1febbf99505%22%20title%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3D6068d7a77b2101c172fc2f003f90b1febbf99505%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3D6068d7a77b2101c172fc2f003f90b1febbf99505%3C%2FA%3E%3C%2FP%3E%3CP%3E3.10.17%20%E4%BF%A1%E6%81%AF%E6%9D%A5%E6%BA%90%3C%2FP%3E%3CP%3E%20%20%20%20%20%3CA%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fcaamalg.c%23L2083%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fcaamalg.c%23L2083%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fcaamalg.c%23L2083%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E4%B8%8D%E6%B8%85%E6%A5%9A%E6%88%91%E4%BB%AC%E7%9C%8B%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E5%90%A6%E5%8F%AA%E5%AD%98%E5%9C%A8%E4%BA%8E%E5%93%88%E5%B8%8C%E7%AE%97%E6%B3%95%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9F%83%E9%87%8C%E5%85%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E5%9F%83%E9%87%8C%E5%85%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20linux%203.0.35%20%E4%B8%8A%E9%9C%80%E8%A6%81%E6%89%93%E4%B8%80%E4%BA%9B%E8%A1%A5%E4%B8%81%EF%BC%8C%E4%BB%A5%E8%8E%B7%E5%BE%97%20CAAM%20%E7%9A%84%E6%AD%A3%E5%B8%B8%E5%8A%9F%E8%83%BD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95700%22%20target%3D%22_blank%22%3E%E9%97%AE%26amp%3B%E7%AD%94%EF%BC%9A%E4%B8%BA%E4%BB%80%E4%B9%88%20iMX6%20%E7%9A%84%20CAAM%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%20Linux%20%E4%B8%8B%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%EF%BC%9F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EJaime%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E6%AD%A3%E7%A1%AE%E7%AD%94%E6%A1%88%E6%8C%89%E9%92%AE%E3%80%82Thank%20you!%3CBR%20%2F%3E-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
