Built Module With Kernel
1,811 次查看
Nirjul_Patel
Hii
We want to compile driver module with kernel but object file is created and .ko ( module file ) is not Created and in board ( dev directory ) node is not created
I attached a file we do process
1,801 次查看
joanxie
you can change the module to "m" replace "y" in the configure file, otherwise you will get built-in module with kernel
