Building examples for iMX8 SDK using GCC ARM embedded Toolchain
2,809 次查看
Ramprakash
Hello Team,
I am trying to build example codes given in the iMX8 SDK archives. I followed the steps given under section 5 of "Getting Started with MCUXpresso SDK for MEK-MIMX8QX". I am currently getting the following error when I try to build the build_debug.sh file. What are the changes required to overcome this error.
Error:
-- BUILD_TYPE: debug CMake Error in CMakeLists.txt: The CMAKE_C_COMPILER: /home/opt/gcc-arm-none-eabi-10-2020-q4-major/bin/bin/arm-none-eabi-gcc
Thanks and Regards,
Ramprakash
2,777 次查看
Ramprakash
Thank you for the reply.
I have downloaded Cmake but the issue got resolved once I set the environment variable for ARMGCC_DIR. I included the /bin along with the installation path. Once I removed it the issue got resolved.
Thanks and Regards,
Ramprakash
2,783 次查看
Bio_TICFSL
Hello
Looks like you need to download the cmake in your host.
