Building HAL layer alone in imx6q
2,648件の閲覧回数
bandarulavanya
Contributor V
Hi all,
I am using imx6q android lollipop version for my imx6q Evaluation board, i can able to compile
make systemimage
make bootimage
make recoveryimage
But i want to compile HAL layer of camera alone and i want to copy the related files to SD card. How can i do that if anyone knows help me to sort it out.
Lavanya
ラベル(3)
タグ(1)
2,530件の閲覧回数
bandarulavanya
Contributor V
I found this.
We can compile only HAl libraries of camera alone like below.
cd hardware/imx/mx6/libcamera/
source build/envsetup.sh
lunch TARGET
ex: lunch sabresd_6dq-user
mm
Lavanya
2 返答(返信)
2,530件の閲覧回数
art
Thank you for sharing your insight.
Artur
2,531件の閲覧回数
bandarulavanya
Contributor V
I found this.
lunch TARGET
mm
Lavanya
