Hi all,
I have been trying to include optee-examples in the NXP Yocto project for several hours now. The normal build for my imx6qpsabresd board works great. I have then added the examples according to the instructions from @Zhiming_Liu (https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Build-optee-examples-in-yocto-hardkott/t...), but unfortunately the build process seems to have problems with the ta files. These cannot be copied because they do not exist. Can someone help me here?
The log is attached to the post. I use the manifest imx-linux-zeus -> imx-5.4.70-2.3.4.xml
Solved! Go to Solution.
 Zhiming_Liu
			Zhiming_Liu
		You need use optee-examples of zeus, that link is tested under hardkott
 Zhiming_Liu
			Zhiming_Liu
Thanks for your answer. I had already found the error with the wrong version.
