Build meta-toolchain-qt6 fail
1,963件の閲覧回数
Mingheng
I finished building image for imx8M Mini lpddr4 evk with rivision imx-6.6.23-2.0.0.
Then I tried to build cross-compiler toolchain with Qt6 by using command `bitbake meta-toolchain-qt6` but return failure when compiling qtpdf. See the screenshot as follow.
1,946件の閲覧回数
Mingheng
Hi again
I tried to create the command I found 已解决: Encounter error when bitbake qtwebengine -cconfigure in imx8 bsp L5.15.32-2.0.0 - NXP Community then rebuild again, but it didn't work.
