Build initramfs and deploy with yocto
3,745 次查看
rans
Senior Contributor I
I've found the following step-by-step instruction for building initramfs
i.MX28: Enable initramfs step by step
But it seems not to use yocto, but ltib buid.
We are building with yocto, does it mean that mkimage step is not required ?
How can I know if it already done or not in yocto build for initramfs ?
Thank you,
Ran
2,339 次查看
Hi Ran
one can start with helpful links:
Initramfs and tmpfs
poky - Poky Build Tool and Metadata
2,340 次查看
Hi Ran
Initramfs and tmpfs
