Build fails while including net-snmp pkg
1,624 次查看
deepak_singh1
I am trying to install LTIB and build. When i  include net-snmp package build fails. following is output-
Processing: expat
Processing: udev
Processing: net-snmp
Build path taken because: directory build, no prebuilt rpm,
scbuild/scdeploy already unpacked package
Build path taken because: directory build, build key set, no prebuilt rpm,
rpmbuild --dbpath /home/deal/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /home/deal/ltib/rpm' --define '_prefix /usr' --define '_tmppath /home/deal/ltib/tmp' --define '_rpmdir /home/deal/ltib/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bc --short-circuit  /home/deal/ltib/dist/lfs-5.1/net-snmp/net-snmp.spec
Building target platforms: arm
Building for target arm
Executing(%build): /bin/sh -e /home/deal/ltib/tmp/rpm-tmp.17783
+ umask 022
+ cd /home/deal/ltib/rpm/BUILD
+ cd net-snmp-5.4.1
+ ./configure --prefix=/usr --host=arm-linux --build=x86_64-unknown-linux-gnu --disable-embedded-perl --without-perl-modules with_endianness=big --enable-mini-agent --with-default-snmp-version=3 --disable-des --disable-debugging --with-sys-contact=who@where --with-logfile=/var/log/snmp --with-transports=UDP TCP --with-defaults
checking what to build and install...  agent apps man local mibs
using default persistent mask 077
using default AgentX socket /var/agentx/master
using default "enterprise.net-snmp"
using default enterprise sysOID "NET-SNMP-MIB::netSnmpAgentOIDs..."
using default notifications "NET-SNMP-MIB::netSnmpNotifications"
using OS default send buffer size for server sockets
config.status: creating testing/Makefile
config.status: creating man/Makefile
config.status: creating mibs/Makefile
config.status: creating net-snmp-config
config.status: creating include/net-snmp/net-snmp-config.h
config.status: include/net-snmp/net-snmp-config.h is unchanged
config.status: executing default commands
            Net-SNMP configuration summary:
  SNMP Versions Supported:    1 2c 3
  Net-SNMP Version:           5.4.1
  Building for:               linux
  Network transport support:  Callback Unix UDP TCP
  SNMPv3 Security Modules:     usm
  Agent MIB code:             default_modules =>  snmpv3mibs mibII/snmp_mib mibII/system_mib mibII/sysORTable mibII/vacm_vars utilities/execute
  Embedded Perl support:      disabled
  SNMP Perl modules:          disabled
  SNMP Python modules:        disabled
  Authentication support:     MD5 SHA1
  Encryption support:         DES AES
+ make
chmod a+x net-snmp-config
making all in /home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/snmplib
touch net-snmp-config-x
make[1]: Entering directory `/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/snmplib'
make[1]: Leaving directory `/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/snmplib'
making all in /home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent
make[1]: Entering directory `/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent'
making all in /home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent/helpers
/bin/sh ../libtool  --mode=compile gcc -I../include -I. -I../agent -I../agent/mibgroup -I../snmplib   -g -O2 -Ulinux -Dlinux=linux  -c -o mib_modules.lo mib_modules.c
make[1]: *** No rule to make target `helpers/libnetsnmphelpers.la', needed by `libnetsnmpmibs.la'.  Stop.
make[1]: *** Waiting for unfinished jobs....
make[2]: Entering directory `/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent/helpers'
/bin/sh ../../libtool  --mode=link gcc -g -O2 -Ulinux -Dlinux=linux  -rpath /usr/lib -version-info 16:0:1 -o libnetsnmphelpers.la all_helpers.lo baby_steps.lo bulk_to_next.lo cache_handler.lo debug_handler.lo instance.lo mode_end_call.lo multiplexer.lo null.lo old_api.lo read_only.lo row_merge.lo scalar.lo scalar_group.lo serialize.lo stash_cache.lo stash_to_next.lo table.lo table_array.lo table_container.lo table_data.lo table_dataset.lo table_iterator.lo table_row.lo table_tdata.lo watcher.lo ../libnetsnmpagent.la ../../snmplib/libnetsnmp.la
gcc -I../include -I. -I../agent -I../agent/mibgroup -I../snmplib -g -O2 -Ulinux -Dlinux=linux -c mib_modules.c  -fPIC -DPIC -o .libs/mib_modules.o
gcc -I../include -I. -I../agent -I../agent/mibgroup -I../snmplib -g -O2 -Ulinux -Dlinux=linux -c mib_modules.c -o mib_modules.o >/dev/null 2>&1
gcc -shared  .libs/all_helpers.o .libs/baby_steps.o .libs/bulk_to_next.o .libs/cache_handler.o .libs/debug_handler.o .libs/instance.o .libs/mode_end_call.o .libs/multiplexer.o .libs/null.o .libs/old_api.o .libs/read_only.o .libs/row_merge.o .libs/scalar.o .libs/scalar_group.o .libs/serialize.o .libs/stash_cache.o .libs/stash_to_next.o .libs/table.o .libs/table_array.o .libs/table_container.o .libs/table_data.o .libs/table_dataset.o .libs/table_iterator.o .libs/table_row.o .libs/table_tdata.o .libs/watcher.o  -Wl,--rpath -Wl,/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent/.libs -Wl,--rpath -Wl,/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/snmplib/.libs -L/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/snmplib/.libs ../.libs/libnetsnmpagent.so ../../snmplib/.libs/libnetsnmp.so  -Wl,-soname -Wl,libnetsnmphelpers.so.15 -o .libs/libnetsnmphelpers.so.15.1.0
(cd .libs && rm -f libnetsnmphelpers.so.15 && ln -s libnetsnmphelpers.so.15.1.0 libnetsnmphelpers.so.15)
(cd .libs && rm -f libnetsnmphelpers.so && ln -s libnetsnmphelpers.so.15.1.0 libnetsnmphelpers.so)
ar cru .libs/libnetsnmphelpers.a  all_helpers.o baby_steps.o bulk_to_next.o cache_handler.o debug_handler.o instance.o mode_end_call.o multiplexer.o null.o old_api.o read_only.o row_merge.o scalar.o scalar_group.o serialize.o stash_cache.o stash_to_next.o table.o table_array.o table_container.o table_data.o table_dataset.o table_iterator.o table_row.o table_tdata.o watcher.o
arm-linux-ranlib .libs/libnetsnmphelpers.a
creating libnetsnmphelpers.la
(cd .libs && rm -f libnetsnmphelpers.la && ln -s ../libnetsnmphelpers.la libnetsnmphelpers.la)
: libnetsnmphelpers.la
make[2]: Leaving directory `/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent/helpers'
making all in /home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent/mibgroup
make[2]: Entering directory `/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent/mibgroup'
make[2]: Leaving directory `/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent/mibgroup'
make[1]: Leaving directory `/home/deal/ltib/rpm/BUILD/net-snmp-5.4.1/agent'
make: *** [subdirs] Error 1
error: Bad exit status from /home/deal/ltib/tmp/rpm-tmp.17783 (%build)
RPM build errors:
Build time for net-snmp: 33 seconds
Failed building net-snmp
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Thu Jan 15 14:32:49 2015
Ended:   Thu Jan 15 14:33:25 2015
Elapsed: 36 seconds
These packages failed to build:
net-snmp
Build Failed
Exiting on error or interrupt
deal@ubuntu:~/ltib$
please help for building
标记 (1)
0 回复数
