Hi NXP support team,
I am using imx8mm chip and try to build custom android uboot and kernel image.
I modify mk files under "device/fsl/" for my custom "lunch" and also add custom device tree and config in uboot and kernel.
After I do my custom "lunch" which is successful i can build android uboot and kernel image by below commands.
"./imx-make.sh bootloader -j4" and "./imx-make.sh bootimage -j4"
But when I try to build android device tree (dtbo.img) with command "./imx-make.sh dtboimage -j4" it shows below error :
FAILED: ninja: unknown target 'dtboimage'
10:47:30 ninja failed with: exit status 1
Or when i try to build whole android image with command "./imx-make.sh -j4" it shows below error which fail on building dtbo.img too :
FAILED: ninja: 'out/target/product/my_test/dtbo-imx8mm.img', needed by 'out/target/product/my_test/dtbo.img', missing and no known rule to make it
11:06:12 ninja failed with: exit status 1
I can find my custom dtb is builded under "out/", but i can't build android device tree image.
Please tell me where i need to modify in Anrdoid 10 BSP for building dtbo.img.
Thanks.
