Build WebRTC on IMX8M Mini using Yocto Project.
4,519件の閲覧回数
SujayBane
I am trying to build WebRTC on IMX8M Mini using Yocto. Refer to the documents IMX_Linux_User_guide.pdf, IMX_YOCTO_PROJECT_USERS_GUIDE.pdf, IMX_PORTING_GUIDE.pdf, etc. for understanding but not getting any link for the build process.
also, no recipe was found to build the WebRTC in the Yocto project and any custom layer addon into it. can anyone help me out to build the WebRTC for IMX8M Mini in Yocto?
Thanks.
タグ(1)
3 返答(返信)
4,457件の閲覧回数
Yoshinori_Kasajima
FYI
I can build libwebrtc referenced by the following build tool.
https://github.com/shiguredo-webrtc-build/webrtc-build
3,163件の閲覧回数
bhupiister
How did you consume the binary that was built?
Did you every try building webrtcsink?
3,131件の閲覧回数
Yoshinori_Kasajima
I use libwebrtc directory.
I feel you want to use libwebrtc for gstreamer.
