Build Linux Kernel for Debugging in Yocto
9,048 次查看
chandiniindavar
Hi guys
I am using yocto setup to build freescale kernel 4.15 version. so that i can debug using tarce32
As i know very step is we need to Build Linux Kernel for Debugging.
Could any one please tell me , what configuration i have to change ?
Thanks in advance
Chandini
6,962 次查看
chandiniindavar
vmlinux file must be compiled with debug info enabled. Thus,
you need to ensure that CONFIG_DEBUG_INFO is enabled in the kernel configuration. You can find this
option under “Kernel hacking -> Compile the kernel with debug info” (in newer kernel versions under
“Kernel hacking -> Compile-time checks and compiler options -> Compile the kernel with debug
info”).
6,963 次查看
chandiniindavar
info”).
6,961 次查看
chandiniindavar
For more information . i am using imx7d-sabre board
