Build IMAX8M Yocto environment task error problem!!!!
1,620 次查看
egbert8165
Hi NXP Team,
I executed the bitbake fsl-image-qt5-validation-imx command following instructions but found a problem (reger below Figure).
After executing the bitbake-c fetchall fsl-image-qt5-validation-imx command and executed the bitbake fsl-image-qt5-validation-imx  to rebuilding it, the following error message still appears. How can I solve this problem? (refer below Figure )
Egbert Liu
标记 (1)
1,540 次查看
Hi Egbert
for building image with QT5 one can look on
wayland image with QT5 fails to build on Yocto Rocko for i.mx8m
