Booting from SD card
1,752 次查看
aabhishekoct18
Hi Team
We made our options  to boot  from SD card during internal Boot, Can you please confirm when clock should come.Does it samples  CD  pin , then clock  will  come  after  ensuring SD  card is there or  something else  ? What is  sequence  of  whole  process?.
How handshaking happen between  SD card and processor ?
1,690 次查看
igorpadykov
Hi Abhishek
sd boot sequence is described in Figure 8-10. Expansion device boot flow,
sect.8.5.3.4 IOMUX configuration for SD/MMC
i.MX 6Solo/6DualLite Applications Processor Reference Manual
>Does it samples  CD  pin , then clock  will  come  after  ensuring SD  card ..
right.
