Hi Surendra
from processor point loading process is described in i.MX6UL Reference Manual
sect.8.7.1 Image Vector Table and Boot Data
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6ULRM.pdf
or for example Figure 1. Typical memory layout AN4581
http://www.nxp.com/assets/documents/data/en/application-notes/AN4581.pdf
also there are some number of uboot environments which control load process,
these are described in uboot documentation
UBootEnvVariables < DULG < DENX
arm - Understanding Linux load address for U-Boot process - Stack Overflow
