Thanks for your reply but you misunderstood me, let me explain again.
The kernel is the same, these are the steps to reproduce:
1) Manually load kernel Image at addr x
2) Run hab_auth_img with the kernel size/offset that I know because I compiled it
3) It returns no events, good.
4) Run booti
5) It automatically run an hab_authentication but if fails... (I found out that is related to a wrong kernel size).
So why with the same Image I'm having this problem?
Paolo
