Boot From SD Card
Boot From SD Card
santoshkadam
Hello All,
I am having a MCIMX6Q SDP board and it's currently booting android 4.0.4 from the nand flash. I would like to boot this device from my SD Card which I have created with android 4.1 image.
Can someone let me know the procedure to boot it from the SD Card ?
thanks and regards
Santosh
Labels (2)
Tags (4)
AlbertT
take a look at the Sabre SD User Guide included in the BSP : you have to change the DIP switch configuration and set switch D2 and D7 to 1, all others to 0.
If you don't know where is your DIP switch : http://www.freescale.com/files/32bit/doc/quick_start_guide/SABRESDP_IMX6_QSG.pdf
AlbertT
santoshkadam
Hello Albert,
Thank you for your response. It worked for me and I am able to boot from the SD card. Once again, thank your for your help.
Santosh
AlbertT
You're welcome !
Don't forget to mark the subject as solved.
