Bluetooth testing on i.MX8M
deexithamba
I am currently working on i.MX8M EVK and encountered with a small issue while testing bluetooth on EVK. How can i enable the bluetooth feature on Android platform. In release note it says "To enable Bluetooth, request the wcnss_filter binary from Qualcomm" , i was bit confused on this!! I was also able to bring  up bluetooth on Linux(4.9.55) on the same EVK but failing on android platform. Can u please look into this and help me in getting up the bluetooth on i.MX8M EVK.
Deexith V
diegoadrian
Unfortunately, this is what needs to be done. I know that with Linux works. However, for Android is different, since the way how Androids interact with the hardware is different. I apologize for the inconveniences this could give you.
Diego.
