Bluetooth not working MCIMX8M-EVK kit
2,357 次查看
shabbirlimdiwal
I am booting fsl-image-qt5-imx8mqevk-20180802213331.rootfs.sdcard from sd card on my imx8m-evk kit. The version of the linux image is imx-4.9.88-2.1.0-8mm_alpha. The board boots fine but seems like on board bluetooth is not working. I ran below commands to test bluetooth after boot,
root@imx8mqevk:~# systemctl start bluetooth
root@imx8mqevk:~# bluetoothctl
Agent registered
[bluetooth]# devices
No default controller available
[bluetooth]#
Any idea why ? I am attaching logs during boot for your reference.
Shabbir
标签 (1)
3 回复数
2,016 次查看
joanxie
what version do you use? pls check the release note, it seems the Bluetooth is not enabled in the default prebuilt image
2,016 次查看
shabbirlimdiwal
I am using imx-4.9.88-2.1.0-8mm_alpha image. Thanks !
2,016 次查看
joanxie
pls refer to the 4.9.88 release note, for imx8M, Supports Murata 1CQ (QCA6174A) Wi-Fi/Bluetooth.For i.MX 8MQuad, it needs to add kernel parameter "pci=nomsi" to support Murata 1CQ Wi-Fi. for more detailed information about bluetooth, you can refer to the release note.
