Bluetooth NINA-B410 HCi interface not able to initialize with IMX8XQP
Akshaya
-When iam trying to initialize the HCI interface it is showing timeout error
-sudo hciattach /dev/ttyLP1 any 115200 noflow
output
-Setting TTY to N_HCI line discipline
-Device setup complete
-[ 656.751608] Bluetooth: hci0: command 0x1003 tx timeout
-When iam trying to know the status of hci interface it is giving me
-hciconfig
output
-hci0: Type: Primary Bus: UART
BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
DOWN
-When iam trying to up the hci config also the above time out error is occuring
-I tried to enable all the required drivers if required in kernel then also the timeout issue still persisit .
-Trying to findout what is causing the timeout issue and how to solve it .
Chavira
HI @Akshaya!
Thank you for contacting NXP Support!
Unfortunately we don't know what the problem could be since is a Nordic Semiconductor chip.
I recommend contacting Nordic Semiconductor support or U-BLOX support to get the driver.
Also if the problem persists you can use one of our wifi solutions and are already integrated in our BSP.
Best Regards!
Alejandro
Akshaya
Hi @Chavira,
Thank you for your response!
If you come across any information regarding this issue, please let me know.
Akshaya
