Blending gray scale images with G2D
1,249 次查看
erlend_eriksen
Is there any way to have the g2d system blend two gray scale images and output a new gray scale image? From the examples I have seen it seems to only accept rgb as output. But maybe it's possible to somehow make g2d do the gray scale bending correctly for a gray scale output, even though it treats it as rgba?
标签 (4)
1,197 次查看
Bio_TICFSL
Hello Erlend,
Sorry the output has to be in RGB, but you can the scale with gray image, but the output should be in RGB format.
