Unfortunately we dont have baremetal Ethernet examples as it is not common to use this module without a TCP/IP stack.
Is it completely necessary to be baremetal? If you share details on your application we can try to find an alternative for you.
I have a presentation which explains alittle bit more about how the buffers work, but you may need to enter a case at www.nxp.com/support
Carlos
NXP Technical Support
