Backlight control on iMX8M Mini on Android 11 OS
Hrithik
Hi NXP Team,
We are working on iMX8M Mini on Android 11 OS.
We have integrated pwm backlight driver (pwm-bl.c) to our code for backlight control of LVDS display.
The backlight is getting properly controlled from the pwm node i.e /sys/class/backlight/backlight_grp/brightness, but we are not able to control it via Android UI backlight slider.
Kernel Changes:
backlight: backlight_grp {
compatible = "pwm-backlight";
pwms = <&pwm3 0 50000>; /*duty cycle in nano seconds*/
enable-gpios = <&gpio1 0 GPIO_ACTIVE_HIGH>; /*LCD_SHUTDWN*/
brightness-levels = <0 4 8 16 32 64 128 255>;
default-brightness-level = <7>;
post-pwm-on-delay-ms = <10>;
pwm-off-delay-ms = <10>;
status = "okay";
init.rc changes:
setprop vendor.hw.backlight.dev "backlight_grp"
chown system system /sys/class/backlight/backlight_grp/brightness
chmod 0660 /sys/class/backlight/backlight_grp/brightness
Could you please help us in solving this issue.
Hrithik
topkarag
is there any change ?
ı have same problem
topkarag
hello, ı have same issue. did you solve the problem ?
%3CLINGO-SUB%20id%3D%22lingo-sub-1468218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBacklight%20control%20on%20iMX8M%20Mini%20on%20Android%2011%20OS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1468218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%20Team%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWe%20are%20working%20on%20iMX8M%20Mini%20on%20Android%2011%20OS.%3C%2FP%3E%3CP%3EWe%20have%20integrated%20pwm%20backlight%20driver%20(pwm-bl.c)%20to%20our%20code%20for%20backlight%20control%20of%20LVDS%20display.%3C%2FP%3E%3CP%3EThe%20backlight%20is%20getting%20properly%20controlled%20from%20the%20pwm%20node%20i.e%20%3CSTRONG%3E%2Fsys%2Fclass%2Fbacklight%2Fbacklight_grp%2Fbrightness%2C%20%3C%2FSTRONG%3Ebut%20we%20are%20not%20able%20to%20control%20it%20via%20Android%20UI%20backlight%20slider.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CU%3EKernel%20Changes%3A%3C%2FU%3E%3C%2FP%3E%3CP%3Ebacklight%3A%20backlight_grp%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22pwm-backlight%22%3B%3CBR%20%2F%3Epwms%20%3D%20%26lt%3B%26amp%3Bpwm3%200%2050000%26gt%3B%3B%20%2F*duty%20cycle%20in%20nano%20seconds*%2F%3CBR%20%2F%3Eenable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%200%20GPIO_ACTIVE_HIGH%26gt%3B%3B%20%2F*LCD_SHUTDWN*%2F%3CBR%20%2F%3Ebrightness-levels%20%3D%20%26lt%3B0%204%208%2016%2032%2064%20128%20255%26gt%3B%3B%3CBR%20%2F%3Edefault-brightness-level%20%3D%20%26lt%3B7%26gt%3B%3B%3CBR%20%2F%3Epost-pwm-on-delay-ms%20%3D%20%26lt%3B10%26gt%3B%3B%3CBR%20%2F%3Epwm-off-delay-ms%20%3D%20%26lt%3B10%26gt%3B%3B%3CBR%20%2F%3Estatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%7D%3B%3CU%3E%3CBR%20%2F%3E%3C%2FU%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CU%3Einit.rc%20changes%3A%3C%2FU%3E%3C%2FP%3E%3CP%3Esetprop%20vendor.hw.backlight.dev%20%22backlight_grp%22%3CBR%20%2F%3Echown%20system%20system%20%2Fsys%2Fclass%2Fbacklight%2Fbacklight_grp%2Fbrightness%3CBR%20%2F%3Echmod%200660%20%2Fsys%2Fclass%2Fbacklight%2Fbacklight_grp%2Fbrightness%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECould%20you%20please%20help%20us%20in%20solving%20this%20issue.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EHrithik%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1468218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EGraphics%20%26amp%3B%20Display%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Backlight%20control%20on%20iMX8M%20Mini%20on%20Android%2011%20OS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eis%20there%20any%20change%20%3F%26nbsp%3B%3C%2FP%3E%3CP%3E%C4%B1%20have%20same%20problem%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2088432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Backlight%20control%20on%20iMX8M%20Mini%20on%20Android%2011%20OS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2088432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%2C%20%C4%B1%20have%20same%20issue.%20did%20you%20solve%20the%20problem%20%3F%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
