Backlight Control
Backlight Control
2,614件の閲覧回数
CurtisWald
The Backlight brightness can be changed from user space using the /sys interface.
$ ls /sys/devices/platform/mxs-bl.0/backlight/mxs-bl
actual_brightness     brightness    max_brightness subsystem
bl_power                  device         power                uevent
To see what the maximum brightness is:
$ cat /sys/devices/platform/mxs-bl.0/backlight/mxs-bl/max_brightness
100
To change brightness
$ echo 100 > /sys/devices/platform/mxs-bl.0/backlight/mxs-bl/brightness
The default brightness is 50.
2,136件の閲覧回数
RobertMGirard
Curtis,
Thanks for this info.
I have been looking for a way to increase the backlight on the EVK
Robert
