BT.656 line Interleave
Kazuma_Sasaki
Senior Contributor I
We will connect 4 NTSC cameras to the video decoder IC like a below figure.
the video decoder IC merges multi-video streams into a single BT.656 output.
In this case, Channel ID(CH ID) is embedded into EAV/SAV's least significant two bits such as below format.
Can i.MX8X series receive these data via parallel CSI interface?
Kazuma Sasaki.
joanxie
i.mx8x support standard bt656 format, bt656 format EAV/SAV 8bits like: 1 F V H  P3 P2 P1 P0
joanxie
Kazuma_Sasaki
Hi Joan,
I appreciate your support. Okay, I got it. I will consider other solution.
Kazuma Sasaki.
