We will connect 4 NTSC cameras to the video decoder IC like a below figure.
the video decoder IC merges multi-video streams into a single BT.656 output.
In this case, Channel ID(CH ID) is embedded into EAV/SAV's least significant two bits such as below format.
Can i.MX8X series receive these data via parallel CSI interface?
Kazuma Sasaki.
Solved! Go to Solution.
i.mx8x support standard bt656 format, bt656 format EAV/SAV 8bits like: 1 F V H P3 P2 P1 P0
Hi Joan,
I appreciate your support. Okay, I got it. I will consider other solution.
Kazuma Sasaki.
