Audio In/Out API iMX53QSB
1,673 次查看
JimElliott
Hello all, this is my first post here, so please take it easy on me :)
Before I begin I just want to start by saying that this is the first time I've ever tried to program an embedded device outside of a simple 8bit PIC using assembly. I do have C programming experience but it is all been middle-ware, network, web, and database type stuff.
So, now that that is out of the way. I would like to write a C/C++ program that grabs audio from the Audio In (microphone) port, processes that data, and then sends it back out the Audio Out (headphones) port. How do I go about doing that - specifically the hardware Audio In/Out part? Is there an API associated with that? How do I address those ports?
And in case it wasn't clear by the 'Discussion Title' I am using the iMX53QSB with whatever version of Ubuntu that ships with newest boards....
Any advice would be greatly appreciated.
Jim
标记 (1)
1,606 次查看
JimElliott
Thank you so much for the response. I'm going to take a look at that link this weekend.
1,606 次查看
KursadOney
I think your best bet is to use the ALSA API. Here is a quick howto document with code examples. You can also check out /proc/asound/ (or use alsa utilities) to find out the audio devices discovered in your system.
