Asynchronous operation(clEnqueueMapBuffer) is not working properly
tetsuro-okuyama
Contributor V
When executing clEnqueueMapBuffer, I want to set the argument blcoking_map=CL_FALSE to make it work asynchronously, but it only works synchronously.
When using OpenCL with i.MX8Mplus, does this function behave in accordance with the OpenCL specifications? Or are there any restrictions?
The SDK version used is 5.4.70 2.3.0.
