[Android][imx8mm] Camera is Wifi not working on default image
1,645件の閲覧回数
avijitnsec
I am trying to bring up Android on iMX8mm board.
  1. I see the camera app is not working. Although I see the camera device is detected by the driver. For display, I am using HDMI monitor and MIPI-to-HDMI converter.
    ov5640_mipi 2-003c: Camera is found.
  2. Wi-F is not working.
    I don't see wpa_supplicant available on the device.
  3. I am running the CTS test, Do we have a test report(CTS and any other) available to compare against.
Avijit
1,636件の閲覧回数
jimmychan
Which version of Android BSP are you using? you may try the latest one.
For you information, here is the BSP web page
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
And the Android User’s Guide​.
1,637件の閲覧回数
jimmychan
1,618件の閲覧回数
avijitnsec
Thank you for your reply. I was trying the same build. I think the problem was with the HW. It is working fine now.
