Android build error
Android build error
sachusanal
Dear all.
I download and compile the source follow by URL i.MX 6 Series Software and Development Tool R|Freescale. select android  5.0
$ source build/envsetup.sh
$ lunch sabresd_6dq-user
$ make 2> &1 | tee build_sabresd_6dq_android.log
This command I get below errors.
make: *** No rule to make target `kernel_imx/arch/arm/configs/imx_v7_android_defconfig', needed by `out/target/product/sabresd_6dq/.config'. Stop.
how to fix this issue?
Please help me to solve this issue.
Regrds
Sachu
weidong_sun
Hello Sachu,
    I tesed the question you encountered. you should forget to set the value of ARCH & CROSS_COMPILE, please check user's guide of android5.0 BSP and re-configure these 2 parameters.
Weidong
sachusanal
Thanks for your reply
let me know i am using android 5.0  for custom build build.my linux pc have 8GB RAM space.
ubuntu 12.04 is installed.
could u please tell me this RAM space is enough for the custom build
balamuruga
Though the thread is very old, just to update.
The error log seems that, the file 'kernel_imx/arch/arm/configs/imx_v7_android_defconfig' is not present in your android source tree.
Possibly issue could be either of below,
1. the imx6 kernel code at kernel_imx folder is not present.
2. the kernel code is not checked out to the release version.
First go to your android code and check 'ls -l kernel_imx/arch/arm/configs/imx_v7_android_defconfig'
And check whether the file is present.
If you find the file, there should not be a problem.
