Android Pie - Wifi Integration
2,001 次查看
achyut_hegde
I can see that, android pie is ported for NXP platforms. I am currently running imx6 with chipset from Marvell.
Which platform is used by NXP for verifying the wifi integration? I would like to use it as a reference point for integrating Marvell. Could you please share the steps/application note for the same if it is present.
1,891 次查看
Bio_TICFSL
Hello Achyut,
The android P is for MX8 and it doesn´t support marvell wifi it support Qualcomm and broadcom devices.
1,891 次查看
achyut_hegde
Thanks for the reply.
Could you please share any steps / changes need to migrate a wifi module from Oreo to Pie?
One more clarification needed.
Does the image shared in the website has the changes needed to integrate broadcom and qcom wifi chipsets?
Achyut
