Android 9 Wifi not working
2,717 次查看
aravinthkumarja
Senior Contributor II
iMX8m Android 9 on boot-up wpa_supplicant exited, below are the logs. After boot-up in UI we trying to on the wifi not nothing happened.
[ 23.443737] init: Received control message 'start' for 'wpa_supplicant' from pid: 3077 (/system/bin/wificond)
[ 23.456558] init: starting service 'wpa_supplicant'...
[ 23.463969] init: Created socket '/dev/socket/wpa_wlan0', mode 660, user 1010, group 1010
[ 23.570263] init: Service 'wpa_supplicant' (pid 3993) exited with status 255
标记 (2)
2,692 次查看
IvanRuiz
Could you please provide us with more information about the Wi-Fi module you are working with?
Thank you.
BR,
Ivan.
2,679 次查看
aravinthkumarja
Hi Ivan,
I'm using Marvel sd8xxx.
2,693 次查看
IvanRuiz
Thank you.
BR,
Ivan.
