(Android 5.0)Patch code for i.MX6Q failed. c_patch does't work
3,605件の閲覧回数
huipingping
We want to run android 5.0 on our I.MX6Q. We download the source code,freescale kernel,U-boot,path. Following the Android User's Guide, we now having a problem when patching. After running source /opt/android_L5.0.0_1.0.0-ga_core_source/code/l5.0.0_1.0.0-ga/and_patch.sh and enters help, it shows this:
Invoke ". and_patch.sh" from your shell to add following functions to your enviroment:
-- c_gotop:  Change directory .....
-- c_patch:  Recover working tree...
Then, running c_patch /opt/android_L5.0.0_1.0.0-ga_core_source/code/l5.0.0_1.0.0-ga imx_l5.0.0_1.0.0-ga does't work. It shows c-patch: commond not found. Why c_patch does't work? Was it really add c_patch function sucessfully when running “  source /opt/android_L5.0.0_1.0.0-ga_core_source/code/l5.0.0_1.0.0-ga/and_patch.sh”. How can we patch sucessfully?
ラベル(2)
3,153件の閲覧回数
jimmychan
I think you may missed some steps. Please try again. It should work.
2.2 Unpacking the Android release package
After you have set up a computer running Linux OS, unpack the Android release package by using the following commands:
# cd /opt (or any other directory where you placed the android_L5.0.0_1.0.0-ga_core_source.tar.gz file, but make sure you have permission to access that directory;
otherwise, c_patch cannot work properly)
please check the permission to access the directory.
5 返答(返信)
3,153件の閲覧回数
amychou
I have the same problem as well.
I also do the step - 2.2 Unpacking the Android release package
and make sure I have the permission to access the directory.
However, it still shows the same result.
Any other steps missing?
Thanks.
3,154件の閲覧回数
jimmychan
3,153件の閲覧回数
huipingping
It‘s OK now. Thank you!!
3,153件の閲覧回数
Babu
Hi Guys,
can some one help me to download "android_L5.0.0_1.0.0-ga_core_source.tar.gz" . I am not able to find it in freescale.com.
3,153件の閲覧回数
jimmychan
You can download the BSP from here:
i.MX 6 Series Software and Development Tool|Freescale
