Android 11 build error when excute ./imx-make.sh
3,262 次查看
ko-hey
Senior Contributor II
Hi all,
I have tried and followed by following user guide for building Android 11 images.
https://www.nxp.com/docs/en/user-guide/ANDROID_USERS_GUIDE.pdf
But I got following error message when I excuted "./imx-make.sh -j4 2>&1 | tee build-log.txt"
./imx-make.sh: line 151: make: command not found
I attached the detail of error message and related files so could you tell me how to solve it if someone have answer.
Ko-hey
3,252 次查看
ko-hey
It solved with following command.
$ sudo apt-get install make
3,253 次查看
ko-hey
