Always on PWM Overlay
776 次查看
rodG
Hi folks,
I am working with a Verdin imx8mp som + Dahlia carrier board from Toradex and created a Buildroot configuration to build a Linux image for this hardware.
The device tree I am using is comprised of the files attached to this post.
I have successfully created overlays to wake up the Linux from Suspend to RAM when a given GPIO is pressed or to interface with an external LCD.
Now I need an overlay that will make PWM2 keep running even when the system goes into Suspend to RAM mode.
Can you please help me with that?
Thank you.
755 次查看
Bio_TICFSL
You have to go with @toradex
