Aiurdemux / imx-parser fails to correctly parse multi-program MPEG2-TS
ソリューションへジャンプ
2,013件の閲覧回数
ottob
Hi There !
Aiurdemux has a bug where it incorrectly parses the second program in the PMT if it re-uses the same Audio PID that is also in use in the first program, see below. No audio stream is detected for the second program. Unfortunately we are unable to fix this as this parsing is done in the "imx-parser" binary. Is there any way to get access to the source code via a NDA so we can fix it ?
/Otto
ラベル(3)
1,975件の閲覧回数
jimmychan
Please contact the local FAE or Marketing for the imx-parser source code request. Thanks.
1,976件の閲覧回数
jimmychan
